Using groups of objects to other projects EVO file
kikeblackberry
Post by kikeblackberry » Tue Oct 16, 2018 2:40 pm
Due to it is not implemented yet in EVO a function that allow copy-paste from one instance (project 1) to another instance (project 2) running at same time I was wondering why you disable the option to make a group of objects as favorite as we can did it with previous versions of EVO. It was a great time saver.
As you can state in this thread, you recommended this method as “workaround”.
https://dxboard.dialux.com/viewtopic.ph ... oup#p95496
EVO 8.0 doesn’t allow to make a group of objects (table and chairs) as favorite, so we must repeat a lot of work when projects are similar.
Re: Using groups of objects to other projects EVO file
Post by kvkozierowski » Wed Oct 17, 2018 6:27 am
You can use the "Combine" function in evo 8.0 to create a new object which you can use as favourite.
I have to admit I have not tried it with older evo versions, but I doubt that it ever worked with a "group" of objects.
kikeblackberry
Post by kikeblackberry » Mon Oct 22, 2018 1:06 pm
Thank you very much for explanation.
That was old habits with version 4 for sure.
