Error opening project
sherming
Post by sherming » Wed Oct 17, 2018 1:09 am
I'm new to dialux and have been working for a month on this project.
after changing the reflection factor of TV surface.
it shows me the following message when I opened this project:
Unbehandelte Ausnahme: External component has thrown an exception.
System.Runtime.InteropServices.SEHException
at Dial.Dialux.ResultsManagement.CResultsManager.OpenOrCreateProject(CResultsManager* , basic_string<wchar_t\,std::char_traits<wchar_t>\,std::allocator<wchar_t> >* )
at Dial.Dialux.Geometry.GeometryManager.LoadFromUserTemp()
at Dial.Dialux.ProjectData.Management.ProjectPersistenceHelper.LoadProject(IArchiveLoadHandler handler)
at Dial.Dialux.ProjectData.Management.ProjectManager.Load(IArchiveLoadHandler handler)
at Dial.Dialux.InteractionFileHandling.LoadSave.LoadSaveManager.LoadProjectDataAndGeometry(String projectFilePath, LoadSaveResult& result)
at Dial.Dialux.InteractionFileHandling.LoadSave.LoadSaveManager.LoadProject(FileInfo fileInfo)
at Dial.Dialux.InteractionProjectHandling.Base.ProjectHandling.LoadProject(String filename)
at Dial.Dialux.Gui.MainWindowFileHandling.OpenFile(String filename)
at Dial.Dialux.Gui.MainWindowFileHandling.OnCommandOpen(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
Can someone help please?
Re: Error opening project
Post by Csuleiman » Wed Oct 17, 2018 7:05 am
Dear sherming,
Please be so kind to provide us with the certain evo project file for further analysis.
It would be of help if you could send us the link to this topic, so that we could better assign this issue. Our email address is 'Support@dial.de'.
Post by T.Magenheimer » Thu Oct 18, 2018 8:18 am
Dear Sherming,
We could repair your project file. Apparently there was an error during the last saving of the project file, which we have to analyze in more detail
I will send you your calculated project file in a few minutes via WeTransfer.
sherming
Post by sherming » Thu Oct 18, 2018 8:51 am
Dear T.Magenheimer,
Thank you so much, the problem is solved, I can perfectly open the project.
Sherming
