MF changing at the whole site
Antoniusz
Post by Antoniusz » Wed Oct 24, 2018 10:53 am
Hi!
For example I have a building with 100 rooms in my project.
I have made calculations using button "Entire project", but now I need to change MF at the whole building/site.
And here there is a problem.
At version DialuxEVO 7.X there was possibility to change MF using tab "Site" and "Fixed maintenace factor" there. See print screen below.
Changing of the parameter in this cell immediately caused message "Results will become invalid...".
And after recalculation MF was changed according to the parameter "Fixed maintenace factor".
It was clearly seen in the documentation.
But now at version DialuxEVO 8.0 this option doesn't work.
Changing of the parameter "Fixed maintenace factor" causes nothing, recalculation doesn't make any changes, in the documentation too.
I know, that there is the possibility to change MF at the each room separatly, but if I have 100 rooms it will take so much time...
After all, this function worked correctly in the previous version, wasn't it?
Why doesn't it work now, could you explaine?
Thanks!
Re: MF changing at the whole site
Post by T.Magenheimer » Wed Oct 31, 2018 9:43 am
Dear Antoniusz,
You must change the maintenance factors for each room or for each assessment zone individually.
