Dialux EVO 8.0 DWG Export - problems with units
erikhagstrom
Post by erikhagstrom » Thu Jan 10, 2019 12:28 pm
Hi!
I like many of my collueges have been experiencing problems with the export function in EVO 8.0.
Description of the problem and settings:
- We use the metric system for measuements and settings.
- Attached and imported dwg is in millimeters.
- When measuring in the model its look ok in meters.
Settings for the dwg to a 2013 is millimeters
settings in dialux
Everything looks fine in autocad
in autocad
When checking the "UNITS" its in Imperial system
imperial
This creates a problem when then working with other collueges in for example electrical department and requiers extra work to change unit system manually.
Am I doing anything wrong?
best regards
Erik Hagström
WSP Sweden
Re: Dialux EVO 8.0 DWG Export - problems with units
Post by Csuleiman » Thu Jan 10, 2019 12:47 pm
Dear Mr. Hagström,
There is no unit in the DWG and by default, inches are always set in AutoCAD. Therefore, you will see this unit there.
Here is an interesting link to the AutoCAD knowledge base:
https://knowledge.autodesk.com/support/ ... D-MEP.html
erikhagstrom
Post by erikhagstrom » Thu Jan 10, 2019 1:13 pm
Thank you for your reply but you link is broken or missing.
/erik
Post by Csuleiman » Thu Jan 10, 2019 1:27 pm
Dear Mr. Hagström,
Apparently the article was moved or deleted by Autodesk. Perhaps you will find more information on this subject in the Autodesk search.
https://knowledge.autodesk.com/search?s ... sort=score
erikhagstrom
Post by erikhagstrom » Thu Jan 10, 2019 1:47 pm
I cant seem to find any useful information, could you possibly explain if I need to change the units in autocad everytime I export the dwg from autocad.
because my autocad settings are already "metric"
/e
Post by Csuleiman » Fri Jan 11, 2019 12:33 pm
Dear Mr. Hagström,
You will need to change the units in AutoCAD everytime you import a DWG from evo.
erikhagstrom
Post by erikhagstrom » Fri Jan 11, 2019 3:55 pm
Thank you for your reply!
But im very confused why the ability to change "scale" is there:
Then it makes no sense why i should be able to change the format. Why is the possibility there?
Is it a known problem that Dialux Evo creates the dwg´s in "imperial" format?
Do you at Dialux have a plan to change it?
best regards
Erik
Post by Csuleiman » Tue Jan 15, 2019 8:53 am
Hello, Erik,
the link to Autodesk seems to be working again. So you can read the article about this topic.
Evo takes the unit used when exporting. The only problem is that AutoCAD by default switches to Inch or Feet.
