Crash with rx580
Ramdeita
Crash with rx580
Post by Ramdeita » Sat Nov 03, 2018 3:21 am
hello I'm having problems with the boot of dialux using an rx580 gigabyte, does anyone know of any incompatibility problem? try with version 7.1 and it does not boot either, send the same error or some solution? if I remove the gpu the program works without problems the drivers of the rx are the last of the manufacturer
Re: Crash with rx580
Post by Csuleiman » Mon Nov 05, 2018 8:59 am
Hello Ramdeita,
Do you receive any error message that you could send us as a screenshot? When does it crash in evo? It would be very helpful for further analysis if you could send us some more details about the problem.
Besides this we would like to recommend you to update the graphics adapter driver from the manufacturer's website of your graphics card and not by the help of Windows. Maybe it is an Intel driver problem.
Please have a look at the following threads from our DIALux board:
http://dxboard.dialux.com/viewtopic.php?f=29&t=80338
http://dxboard.dialux.com/viewtopic.php?f=29&t=80337
http://dxboard.dialux.com/viewtopic.php?f=17&t=78016
Afterwards please try to download and install our newest evo version by using the following download link which leads you directly to the DIALux setup.
DIALux evo 8.0 patch 3: https://b2b.dial.de/index.php/s/79MviIzDReBTcmJ
We would like to recommend you to deactivate all your security software (virus scanner) once on your computer system and after this please check if you can run the installation of DIALux evo8.0 without any problems.
If the problem persists, please install our previous version evo 8.0 patch 2 with the following setup on your computer.
DIALux evo 8.0 patch 2 Download-Link: https://b2b.dial.de/index.php/s/KiGLUVVCu34eOfF
