Starting Dialux, failure on 52%
sifatullah
Post by sifatullah » Wed Oct 09, 2019 10:52 am
Hallo There
I am a student at the Dania College in Denmark, and I am trying to install the DIALux evo 8.2 on my computer, which is capable of running Revit 2018.
I have been trying to install it 3 times, but get the same error every time.
Could somebody help med here?
I get the following error on my pc:
Unbehandelte Ausnahme: Destinationen for en aktivering udløste en undtagelse.
ved System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
ved System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
ved System.Delegate.DynamicInvokeImpl(Object[] args)
ved Dial.Dialux.Classlib.Tools.ModuleLoader.InvokeRegisteredInitMethods()
ved Dial.Dialux.Classlib.Tools.ModuleLoader.InitializeModules(IEnumerable`1 modules, Action preDelayedInitAction)
ved Dial.Dialux.Gui.DIALuxModuleLoader.InitializeModules()
ved Dial.Dialux.Gui.MainWindow.DelayedOnLoaded()
ved System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
ved System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Inner Exception:
ved System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
ved System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
ved System.Activator.CreateInstance(Type type, Boolean nonPublic)
ved System.Activator.CreateInstance(Type type)
ved Dial.Dialux.Gui.Controls.Main.ModeControlMapper.GetContentForMode(Type modeType)
ved Dial.Dialux.Gui.Controls.Main.ModeSelectionControl.DelayedInit(ModuleLoaderEventArgs args)
Inner Exception:
System.Windows.Markup.XamlParseException
Aktiveringen af konstruktøren på typen 'Dial.Dialux.Gui.Controls.CAD.RenderView', som svarer til de angivne bindingsbegrænsninger, udløste en undtagelse.
ved System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
ved System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
ved System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
ved System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
ved Dial.Dialux.Gui.Controls.Modes.CAD.CadModeSubControl..ctor()
ved Dial.Dialux.Gui.Controls.Modes.CAD.BaseCadModeControl.CreateCadModeSubControl()
ved Dial.Dialux.Classlib.Tools.ModuleLoader.DelayedInit(DelayedInitMethod delayedInitMethod)
ved Dial.Dialux.Gui.Controls.Modes.CAD.CadModeControl..ctor()
Inner Exception:
System.AccessViolationException
Det blev forsøgt at læse eller skrive i en beskyttet hukommelse. Dette kan ofte være et tegn på, at en anden hukommelse er beskadiget.
ved Dial.Dialux.Geometry.ScenegraphControl.Create(ScenegraphControl* , Void* , ISettingsProvider* , IPolygonHelper* , IUserAdviceHandler* , IRedrawTrigger* , CRenderListener* )
ved Dial.Dialux.Geometry.GeometryManager.InitScenegraphDevice(IntPtr hWnd, ModuleLoaderEventArgs args)
ved Dial.Dialux.Gui.Controls.CAD.RenderView.InitSceneGraph(ModuleLoaderEventArgs args)
ved Dial.Dialux.Gui.Controls.CAD.RenderView.DelayedInit(ModuleLoaderEventArgs args)
ved Dial.Dialux.Gui.Controls.CAD.RenderView..ctor()
Re: Starting Dialux, failure on 52%
Post by Csuleiman » Wed Oct 09, 2019 11:17 am
Hello sifatullah,
Please have a look at the following thread:
https://dxboard.dialux.com/viewtopic.ph ... se#p107121
