Glare Rating (GR) calculation
Sentinel
Post by Sentinel » Thu Nov 21, 2019 7:35 am
Hello
Is there a difference how Dialux evo calculates the GR number compared to Dialux 4?
I had to redo a football field in evo. All luminaries, their position, GR settings are the same. In the calculation results all other numbers are the same (lx, uniformity), only GR number doesn't match. In evo it's 59, in Dialux 4 it was 46. Any explanation for this?
Thank you.
Re: Glare Rating (GR) calculation
Post by Csuleiman » Thu Nov 21, 2019 10:08 am
Hello Sentinel,
We wonder if you could send us your evo and also DIALux 4 project file for further analysis. We would like to look at the GR differences between the two projects directly in comparison.
Sentinel
Post by Sentinel » Thu Nov 21, 2019 10:37 am
Hello Csuleiman,
The thing is that I don't have the old Dialux 4 file. That's why I had to re-create it in evo from the old documentation PDF.
From your answer I gather that there is no known issue when calculating GR in evo? No similar issues from other users?
Thanks.
Post by Csuleiman » Thu Nov 21, 2019 10:49 am
Hello Sentinel,
We are not aware of any problems from other users concerning the GR calculation in evo. If you want to compare both DIALux projects, they must be exactly the same. There are some parameters to consider and to set equal, like the maintenance factor, the GR calculation according to EN12464 or CIE112 and so on.
