Broken plane on an object issue
andersoncheng
Post by andersoncheng » Fri Aug 13, 2021 1:37 am
Hi Dialux Export,
I often use Sketch-up model as 3ds file then import it to Dialux Evo.
I always have the issue that a simple plane becomes two triangles.
Any way that to produce a simple and clean surface?
BR,
Anderson
Plane and Triangle 2 .JPG (47.91 KiB) Viewed 778 times
Plane and Triangle .JPG (30.72 KiB) Viewed 778 times
Re: Broken plane on an object issue
Post by kvkozierowski » Fri Aug 13, 2021 8:40 am
Hi Anderson,
The surfaces in 3ds files are always triangles. It is a limitation of the file format.
Perhaps you can try to import your model as .sat file, the surface should be "clean" of triangles.
Users browsing this forum: No registered users and 6 guests
