Problem with Light loss factors
Bushair
Post by Bushair » Fri Feb 01, 2019 9:40 am
I enter the light loss factor in the Settings tab - General Options. However, the value entered there is not the same as the value that the software uses when it performs the lighting calculation. For instance, I enter a light loss factor of 0.70 in the General Options page. However, the light loss factor stated in the output calculation report is not 0.70, it is 0.80. I request someone to explain to me why there is a difference in the light loss factors here and how I can resolve this problem. Please see the attachments which make my query very clear.
I request a clarification on the query raised above. Thanks
light loss factor in output calculation.jpg (208.86 KiB) Viewed 2087 times
light loss factor setting.jpg (63.34 KiB) Viewed 2087 times
Re: Problem with Light loss factors
Post by Csuleiman » Fri Feb 01, 2019 10:36 am
Hello Bushair,
If you change the value for the light loss factor in the standard settings, this value is only adopted in the new projects. I.e. you would have to accept the value once with the OK button and then start a new project or a new exterior scene.
Bushair
Post by Bushair » Tue Feb 05, 2019 11:10 am
