Upload DPF into Dialux
Eduardo Villalobos
Post by Eduardo Villalobos » Sat Oct 15, 2022 12:29 am
Hi
I need to create a project, but the information provided for the Owner is a PDF with the architecture plan. How can I do to update this info instead of starting from scratch?
Thank you in advance,
Re: Upload DPF into Dialux
Post by Csuleiman » Mon Oct 17, 2022 6:47 am
Hello Eduardo Villalobos,
You can only import PDF files into evo via a snipping tool. So in your case, you can import the PDF document as an image file into evo and do the lighting design. Unfortunately, it is not yet possible to import the PDF file directly into evo. This point is still on our improvement list for the coming evo versions.
