Different heights in same BUILDING
seanmj
Post by seanmj » Thu Sep 30, 2021 7:56 am
Hi there,
I hope someone can help me. Im about to calculate some LUX values in one a big warehouse. The problem is that the building has different heights, one place its 5,8 and other places 3,5. How can i do that? I know how to change in rooms, but as mentioned, this is one big building.
Thank you
Re: Different heights in same BUILDING
Post by Csuleiman » Thu Sep 30, 2021 8:00 am
Hello seanmj,
In order to get such a building you have to insert suspended ceilings into the rooms to get the different heights as required. You can insert a suspended ceiling in every room to reduce the height of a room in a storey. Besides this, you should construct the storeys and use the cutout-tool for the openings.
Under the following link, you will find some helpful video tutorials which could assist you by construction such a building:
https://www.youtube.com/results?search_ ... rey+height
