*** SOLVED ***
Hi again, I solved it - kind of!
Sort answer - Install Dialux Evo 10.0 x64
Obviously from my end, all drivers etc are fully up to date, as is the OS and I uninstalled and reinstalled Evo 10.1 at least 3 times.
- As Dialux 4.13 worked I decided to test Evo 9.1 which worked perfectly.
- From 9.1 I upgraded to 10.1 but this failed again - same story.
- I uninstalled 10.1 and installed 10.0 which works perfectly.
The issue is with 10.1
I hope this helps.
Problem with Parallels - Macbook Pro M1 chip
Re: Problem with Parallels - Macbook Pro M1 chip
Dear users,
Thank you for your feedback! We will also test this in the near future and then we can offer customers a workaround for future problems.
Dear Yekrallum,
Thanks for your solution, I will try to install it your way.
Stupid question: I can not find a download link for the 9.1 version??
And once installed, do I have an option to update to version 10, or will version 10.1 be the only option?
Best
Jitze
Best
Jitze
Dear Jitze,
If you want a download link for an older evo version, we can send it to you.
Dear Magenheimer,
Please send me a download link for the versions 9.1 and 10
Thanks a lot
jitze@me.com
Thanks a lot
jitze@me.com
Hello Jitze,
here you will find the download links to our older evo versions.
DIALux evo 10.0 patch 1: https://b2b.dial.de/index.php/s/fII5iKlIRzpgYCs
DIALux evo 9.2 patch 3: https://b2b.dial.de/index.php/s/w1BRVtWm5hx8OhV
DIALux evo 9.1 patch 1: https://b2b.dial.de/index.php/s/bRyOa3clfnYnFuF
Great Thanks, I will let you know the results
